Irish mobile
  • 15 November 2018
  • 64 views
Why can’t I call Irish mobiles from my iPhone? I thought it was included in my plan??
Also does anyone else have HUGE problems
making contact with real
ppl at ID mobile?? App not very user friendly! Sorry you can probably tell I get really frustrated!!
Just a wee silly question. Did you put +353 before the phone number that you are trying to call?
Also did you make sure if this setting is turned on?
Userlevel 2
HI Gjon05, as Hikari has mentioned, you'll need to make sure you use the international dialing code.
Calls to foreign numbers are not included in your plan so if you have your cap set to 0 or have reached your existing cap, the call would not be connected.
Phil
