No 4G in Spain, 3G ok
  • 31 July 2018
  • 606 views
Hello there.
I have a new iPhone SE with SIM-only on iD Mobile.
Roaming in Spain (Movistar), 3G data works ok but no 4G. Roaming and 4G voice/data enabled on phone. Another iPhone (non-iD Mobile) sat next to me also connected to Movistar gets good 4G coverage.
Any ideas? Pretty sure 4G was working at home in the U.K. before this trip.
Rory
Best answer by Guejar53 1 August 2018, 15:56
Kevin,
Thanks for the response.
I did try manual network connection to Orange and Vodafone but got No Service.
I am back in the UK now; 4G working on iD again, no changes to phone setup.
Rory
Badge +8
Howdy @Guejar53
Could you try manually connecting to another network over there to see if this allows you access to 4G?
Kevin
Kevin,
Rory
It's completely odd that you weren't able to access a 4G connection @Guejar53.
It's hard for us to investigate international coverage issues as the masts aren't owned by us.
We're glad that you were able to connect to a 3G connection at a bare minimum though.
