Best answer by Gregor
View originalno SIM detected in Gabon
I travelled to Gabon beginning of January (still I am there) and no sim detected since then. Tried to restart many times and tried on a different phone but it always say no service. I called the customer service and they suggested to search for the network manually but it led to the same outcome. The Sim was working fine in the UK and Europe.
Hello @robi_b , as @Hikari has mentioned above, we do not provide roaming services in Gabon which is why you're unable to connect to a network.
You can head to https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges and use the "Roaming" tool to see if we provide services in a country.
If rates show for that country, this would mean you can connect to services whilst abroad.
If we don't provide service, you'll see the message "Not Available" as above.
The following countries are inclusive of your allowances though.
Why iD
Mobile?
