phoning from canaries to uk
  • 24 February 2020
  • 6 replies
  • 58 views
I am getting message "the number you have called has not yet been assigned to a client" when phoning from the canaries to a uk landline.
Hey @Vicm
I think it might be the same issue as another user reported when trying to contact UK number from USA. Have a look here and let me know if that helps to solve your enquiry.
Kind Regards
Gregor
Badge +8
Be sure to update us with whether the above helped or not @Vicm
We’ll be happy to find out more and get you answers if you’ve yet to get this resolved.
HI.
I think the problem is with my phone,HTC Desire 530.
I can call numbers from my phone book with no problems.
However i am getting the above message when I dial a number manually.
I assume I am not entering the dialling code correctly?
Thanks for your  help.
Vic.
Badge +8
Are these local numbers in the Canaries you’re trying to reach @Vicm
The dialling code for the Canary Islands is the same as mainland Spain I do believe.
So you’d want to dial 0034 before the number.
Hi.The numbers I have been trying are to the UK.Do I dial 0044 01etc.or do I leave out the 01 after the 0044?
Hope I have explained myself?
Thanks,Vic.
Badge +8
Hi again @Vicm
To call United Kingdom from Spain, dial: 00 - 44 - Area Code - Land Phone Number
-or-
00 - 44 - 10 Digit Mobile Number
Ignore the dashes, as you wouldn’t leave any spaces.  Be sure to drop the zero you’d normally use at the start of a phone number (when at home) too.
