Best answer by Gregor
View originalReceiving Calls Abroad
Can I receive calls from the UK with data roaming switched off? I’m on vacation in Switzerland which is not one of ID’s included countries and want to avoid excessive charges
Hi @nickyphil
You can receive call while roaming and your mobile data off but you will be charged £2.40 for every minute on the phone. Unfortunately if roaming is not included in your allowance it will be charged both way, when you make a call and when you receive a call.
Kind Regards
Kind Regards
Thanks Hikari, that’s helpful to know.
Why iD
Mobile?
