Best answer by Mohammed
View originalRinging abroad
I am trying to ring home from Murcia and keeps saying I need to connect number with client!! I can't ring out at all.
Hi dimples, are you able to receive calls and use texts?
Are you using the +44 dialing code to reach the UK?
Can you see what network you are connected to, you should be able to use Yoigo or Movistar whilst in Spain.
-Phil
-Phil
Hi, yes can receive calls, texts etc. Only thing won't let me do is ring out. It says number needs to be assigned to a client. I also tried 044 code to no avail and am on Movistar, very strange. Thx for reply.
Hey @dimples ,
To confirm, the UK Dialling code is +44 not 044.
For example, the sample number 0777 111 222 3 would be +44777 222 3 (without the spaces).
So the 0 is replaced by +44.
Can you try this and confirm if this works?
EDIT: I've moved your topic to the Coverage, international & roaming section of our community.
Well thank you Mohammed, success 😁. I hv never had any problems before as usually just dial out from contact list so good for future use. Pity live chat didn't tell me that, back home tomorrow and hvnt been able to ring!! Very much appreciated.
Why iD
Mobile?
