Roaming costs in USA
  • 8 April 2019
  • 1930 views
Im going to the usa on holiday can I use my minutes and data there or do I pay extortionate rates to use it
Best answer by Gregor 8 April 2019, 14:00
Hi @Deaneboy69
Unfortunately there is no way to lower the cost in USA.
I have included below charge that occur for using roaming in USA just in case.
I am sorry I couldn't help you more.
Kind Regards
I am in the states and my phone is not using its monthly allowance plan but it is using up my capped limit
what can l do?
Hl @Carol-Ann
Unfortunately there is nothing that you can do. Roaming in USA isn't cheap so I would recommend you to use WhatsApp or Messenger on WiFi as often as you can.
Below I have included a screenshot of charges occuring while roaming in USA.
