Im having issues roaming. I followed the guide to roaming so Data roaming is enabled on app and handset. I have full reception on Movistar 3G and an R next to it so I know it should work. But I cannot get on the net or send texts or use apps like gmaps. Anyone had this experience before? If I had no reception I would understand but there is full connection. WiFi all works fine so it's not a handset issue. I've turned handset on and off several times, same for settings. My wife has the same problem, shes also on ID! Any ideas anyone? Thanks.
Best answer by Mohammed
