Best answer by Mohammed
View originalunlock phone for international use
I just arrived in Ghana and will be here on business for 3 weeks. I need to get a local sim for local calls but my phone is apparently locked. How do i get this unlocked as I was told when I bought the phone it was unlocked
Hello @damoah89 ,
Just to clarify, we can unlock your handset for use on a UK network provider.
If you'd like to unlock your handset for international use, you'd need to speak to the retailer from where you purchased your handset for guidance. If you got the handset from us, or Carphone Warehouse, then our handsets are sold for UK use and we do not guarantee use with international SIMs.
Userlevel 2
as you need it doing quick nip into any phone shop that isn’t tied to a line provider ...ie not an O2 shop etc and ask them if they can unlock it , depends on phone you have.
Why iD
Mobile?
