Call Forwarding and Caller ID
  • 3 April 2020
  • 158 views
Issues with the toggle on Caller ID and Call Forwarding not working quick fix solution
Call Forwarding short codes
from your phones dial keypad type one of the following:
Turn on call forwarding to a number (prevents calls to your number)
*21*PhoneNumber#    then press send
Turn off forwarding
##21#          then press send
Call Forwarding Status
*#21#          then press send
Caller ID short codes
#31#     then press send - this will show name and number on outgoing calls
*31#     then press send - this will hide name and number on outgoing calls
Hello @Sajidhilltop,
Did you need any help?
