Communcation problems abriad
  • 22 February 2021
  • 33 views
I am living in Norway at the moment (unable to travel to UK).
My iphone6  has “no connection”. I’ve tried using the sim card in other phones. Still no communication.
Also i’ve tried my phone with a Norwegian SIM card which works fine.
I suspect that there is something wrong with the SIM card. Can anyone confirm this? How do i go about obtaining a replacement SIM card when living abroad unable to travel to Britain at the moment?
Hi @Robert59
Has your iD mobile sim worked fine in Norway up until recently? Or has this not worked at all since you have been there?
-Mohsin
Hi @Mohsin
My phone worked fine until two weeks ago. I think there must be a fault in the SIM card? My network provider in Norway confirms that Id mobile should work in Norway.
Robert
Hi @Robert59
We will send you a Private Message so we can investigate this on our end. To view the message sent.  Simply click on your profile icon in the top right, then go to your private messages.
-Mohsin
