I can't send messages between iphone Just sms text
Please can you try the following:
6) Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under “Start new conversations from:”.
Let us know how you get on.
-Mohsin
Please go into settings of your iPhone, scroll down until you see the “Phone” section and click on it, once here click on “My Number” part and delete all the digits and click save, then turn your iPhone off and back on, then go back into the “My Number” section and add your number back in, this should reset it, now go to settings again and search message, click on send and receive and select your number and deselect and other number or email, now do the same for FaceTime by searching facetime at the top of the settings, do the same as with message and it should be working after this.
-Mohsin
