I need a PAC code to take my number with me to a different provider. I have text PAC and my date of birth to 65075, but the text won't send. How do i get my pac number?
Hello
If you login to your iD My Account online, you can request a PAC.
You can also request a PAC using the iD Live Chat service here.
Anyway, good luck!
Let us know how you get on after following the advice from
Unable to get my pax code. None of the suggestions work
Hello
That sounds frustrating - what different ways have you tried to get a PAC number?
You can get a PAC by calling 7777, use option 4 then select the option for leaving ID.
You might also be able to get a PAC number in a Currys or Carphone Warehouse store.
Good luck anyway.
