How can I upgrade my data?
If you log in to your ID Mobile account from your Dashboard go to My Add-ons...
Our add-ons are great if you need to give an allowance a one-off boost.
If you’re always running out of mins, texts or data, why not simply change plan
('My account' > 'Manage my plan' > 'Change my plan')? It'll change the same day, and won't affect the length of your contract.
That’s really helpful, Thanks so much.
Changing your plan would generally be the better option to save you money and net your more data.
Any issues though, just let us know here.
Take care.
Can I increase my data allowance from 250 to 500MB please?
You would need to do this via the App.
My account should have an option to change your plan if you are eligible to do so.
Hope this helps
Regards
Aklima
