How do I switch from a Pay monthly plan (well past the contractual period so no problem there) to Pay as you go? There doesn't seem to be any option to do so within the account. 'Change plan' doesn't offer PAYG options. The only other option is 'End plan'. It's important to me to retain the number for PAYG so I don't want to go ahead and cancel the plan unless I'm sure I can keep the number.
Hi jg2182,
Unfortunately, this is not something we're able to do currently but we can provide you with a PAC to transfer your number to another network in order to retain it on PAYG.
The PAC can be obtained using the app or website my.idmobile.co.uk
Phil
Phil
Phil
Hi Phil,
What if I'm not trying to move to another network? Is there no way I can get a PAYG on ID without going through a PAC code and ordering a new SIM?
Hi @jg2182 ,
I'm afraid that we don't have a process for this in place at this time. The only way to do something like this at present would be to port your number away from us and then back onto the pay as you go SIM afterwards.
I recently just got a 1 month rolling contract but decided I don't really use my phone often enough to keep paying monthly for the data which I don't use. I would like to end this monthly contract but I would like to stay with iD as a pay as you go customer.
Is there any way I can just end the monthly plan and use my sim as a normal top up pay as you go, or do I need to order a brand new PAYG sim and convert my number over?
Why iD
Mobile?
