Updrade
  • 25 January 2019
  • 107 views
I’m on the iPhone SE at the moment but due an upgrade in just over a week, does anyone know if I’ll be able to upgrade to the iPhone 8 or 8plus
Best answer by Gregor 25 January 2019, 18:51
Hi @Andrewcrook2000
I can't tell you 100% what is going to be your upgrade offer as you will be able to see it when you login to your account using ID Mobile app but I can tell you that I am already eligible for an upgrade with ID and app shows me that I can get iPhone 8 for £29.99 a month with 2GB data and zero upront. I am not sure if you will get the same offer though. The best is to wait until you can see what on offer for you.
Regards
