Best answer by Ryan
View originalWill we ever be able to use iD sims in non-smartphones?
A while ago when I first took out an iD phone monthly sim, I wasn't able to use it on my phone because it wasn't a smartphone (had to be some generation of device). I would greatly appreciate being able to use it in a dumbphone.
Hi @HereticHenry ,
Welcome to the iD Community!
Our SIM cards can only work with a phone that can connect to a 3G network or above.
If you can find a phone that suit your needs and can also connect to the 3G spectrum then our SIM cards will work. I'm afraid to say that if your phone can only connect to the older 2G network or below, then this may not be compatible in the future.
I hope this helps.
I hope this helps.
Why iD
Mobile?
