What happens if I run out of an allowance when I'm roaming?
  • 20 January 2020
  • 260 views
Badge
If you're in one of our 50 Inclusive Roaming destinations and use an allowance you've run out of, the following charges will apply:
If you're in a Band 1 destination and text or call a) the UK, b) the same destination you're in, or c) another Band 1 destination, you'll be charged standard UK out-of-plan rates. If you text or call any other destination, you'll be charged the same rate as if you made that call or sent that text from the UK.
If you're in a Band 2 destination and text or call the UK or the same destination you're in, you'll be charged standard UK out-of-plan rates. If you text or call any other destination, international rates will apply.
See our roaming rates page to find out more.
Continue searching on our Community
or
Speak to us on Live Chat.
Be the first to reply!
