calling Isle of Man
  • 23 November 2020
  • 78 views
I've been trying for a week to call a number on the Isle of Man
But keep getting a recorded message "Sorry it has not been possible to connect your call".
Am I unable to call there with idmobile?
Hi @michael_hoeben,
You should be able to call the number just fine, but you’ll need to ensure roaming is active. Once done, you’ll need to make sure that your billing cap is high enough to allow the charge of 40p per minute.
Also, take off the 0 and try to add 0044 to the start of the dialling code if you face further issues i.e 00441624 instead of 01624.
