Want to know how to use data in Bangladesh?
Best answer by RentalLeader
View originalWant to know how to use data in Bangladesh?
View originalYour Simcard will work in Bangladesh. However, it’s not included in ID inclusive EU Roaming so you will be subject to additional charges, all of which can be found here → https://www.idmobile.co.uk/help-and-advice/international-and-roaming-charges. All you have to do is make sure that roaming is set to on using the ID Mobile app or My Account on the website.
Hope this helps :)
