Data rollover when abroad
  • 9 August 2022
  • 376 views
Thinking of coming over to ID from Three and just checking I understand everything.
If I’m on holiday abroad for a month or two, does my previous month’s unused data still rollover and can I use that in addition to my fair usage allowance or would I lose it? The allowance seems really light compared to other providers.
Any other pros and cons you experienced users are able to share about ID Mobile?
Thanks x
Best answer by andewhite 9 August 2022, 16:26
You’ll only be able to use your data allowance (including any rollover) in the 50 inclusive EU roaming destinations.
Inclusive EU roaming comes as standard on all iD Mobile plans, allowing you to roam like at home in 50 destinations across the EU and beyond.
The minutes, texts and data you use simply come out of your plan’s monthly allowances - subject to our fair usage & open data policies (scroll down to the “Open data policy” section).
The open data policy restricts the amount of plan data you can use when roaming, before you start paying roaming rates for data.
