Hi, is it possible to buy a package for roaming when travelling to an international destination that isn’t in zones 1 or 2?
I don’t think so
The pay monthly plans don’t have any add-on options other than for UK data and UK voice minutes. PAYG might be different, but I suspect not.
In the case of a Pay monthly plan, any roaming charges would be applied directly to your account and paid by direct debit when the bill was due.
You might need to increase the amount allowed in your account’s “Cap My Extra Usage Charges.”, to ensure you can actually use your phone when roaming outside Band 1 & Band 2.
Anyway, good luck.
It’s not possible to buy international roaming packages/addons as we don’t offer this, however. if you are in any of the inclusive roaming destinations then add-ons will work fine.
Mohmamed
