Roaming calls from UK to Greece
  • 29 November 2020
  • 108 views
Can I use the existing plan I have to call Greek numbers ( landline or mobile) at NO extra cost?
Best answer by Kevin 4 December 2020, 20:31
Hi there @makmak
If you’re currently in the UK, then calling ANY overseas country will count as an international call.
If you’re out on your travels of Europe though, then you can call other European countries (whilst roaming) as part of your standard allowances.
Head over to our website here:
If you want to find out the costs to call Greece and such.  You may need to increase your spending cap on your iD Mobile account if you have it set to low to be able to make chargeable calls.
Any further questions, just ask.
Hi there @makmak
