travel to turkey
  • 30 June 2022
  • 6 replies
  • 1493 views
can you use your data in turkey when on holiday
Best answer by andewhite 30 June 2022, 16:32
If you mean can you roam like home - then NO.
You can’t use your plan’s UK call, text and data allowances while you’re in Turkey.
The roaming rates for Turkey are below:
thanks for that will this aslo be for unlimited data in uk ? if so can you upgrade before you go ?
thanks again
Your unlimited UK data can’t be used in Turkey.
Unlimited UK data is restricted when you’re taking advantage of iD inclusive roaming.
Refer to iD Mobile’s online Fair usage & open data policies information page.
Thanks do you know if there is a help line i can call ?
Sorry @Kenny Reilly, iD Mobile are 100% online for help & support - there is no telephone support (unless you’re thinking of leaving).
Userlevel 3
Badge
Why are iD mobile’s roaming rates so high compared to TalkMobile
https://talkmobile.co.uk/roam-charges
iD are charging 15x as much per MB for data and rates for all categories are also Much higher at iD
