The ID Mobile help pages say..
"3. Use your phone like at home.
Minutes, text & data will come out of your allowance*.* You can use your minutes to call someone in the UK or the same destination you're in. You'll be charged for calls to all other non-UK destinations. (Note: if you're in the USA or Australia you can call other UK numbers, but USA or Australian phone numbers will be charged at international rates)."
I've set my plan excess to £0 to avoid excessive data roaming charges and am loathe to amend this.
So, can I call the UK using my plan minutes and if so, what do I need to do this? Or have I misunderstood this?
Best answer by Mohammed
