Will my phone work in Russia?
  • 13 June 2018
  • 318 views
Hello, I'd like to know if my phone will work in Russia as its not listed as an EU roaming destination on the ID mobile website
If it will still work under roaming, where can I find what the call / text/ data charges will be?
thanks in advance!
Best answer by Chloe 14 June 2018, 18:25
Userlevel 3
Hi @rich79
So long as you have the correct APN settings and roaming is turned on via the iD Mobile app, you should have no trouble using your device in Russia.
Please check your APN settings match ours:
iD Mobile APN settings
Although you can use the device in Russia, you will be subject to roaming charges, details of which can be found here:
Roaming rates
Let us know if you have any more queries or concerns.
Chloe.
