Apple’s latest smartphone – the iPhone 15 – is already being challenged by a new kid on the block. The Nothing Phone 2 has been dubbed ‘the iPhone killer’. Sounds kind of dramatic, right? Well, there’s some truth in it. These are two super speedy, powerful phones packed with all the latest mobile tech. Making this a heavyweight phone clash for the ages!
So, we’re here to see how the pair stack up against each other. We’ve picked out a few of their biggest advantages to find out what makes them tick. Hopefully our handy comparison will help you to make the right call…
iPhone 15
Does Apple’s latest need much of an introduction? The iPhone is one of the most popular handsets for a reason…
- More battery
When it comes to longer battery life, the iPhone 15 takes this one. If you’re away from a plug socket all day – or, god forbid, you left your charger at home – it’ll easily last a full day without needing a top up. So, you can stream your favourite shows, beat your high score, and listen to a load of tunes. But still have plenty of juice leftover too!
- Improved brightness
We love the sun as much as the next guy. But it can be a right pain when you’re trying to see what’s happening on your phone. Luckily the iPhone 15 has a seriously high peak brightness of 1644 nits. Even when the sun’s beaming down on it, everything stays nice and clear. Meaning if you’re sat by the pool on your summer holiday, it won’t get in the way of your eBook or the playlist you’re trying to make.
- IP68 protection
Just dropped your iPhone in the paddling pool? Don’t go off the deep end. Apple have given the iPhone 15 a waterproof body, with an IP68 design that means it can easily survive a quick dip and splashes from the kids. Phew.
- 4K video on the front camera
If you fancy yourself as the next big YouTuber, then the 4K front facing camera will make your vlogs look even better. And if you’re just a regular average Joe, video calls will get the star treatment too.
- Software support
Apple have come out and told us that they’re committed to supporting the iPhone 15 with updates for the long term. That means you’ll get all the latest security improvements and fun features for the foreseeable. And that’s great news, because you won’t feel like you have to upgrade every year just to keep up!
Nothing Phone 2
What’s the Nothing Phone 2 got going for it then? Well, definitely not nothing. There’s plenty to like about it…
- Bigger screen
For a start, its screen is a real looker. It’s 0.6 inches bigger than the iPhone 15. So, if you want to make everything you watch or play even more immersive, it’s a great shout. It’ll definitely help to take those long morning commutes to the next level!
- Higher refresh rate
Speaking of gaming, the display is also rocking a 120 Hz refresh rate. That means your gameplay is going to be silky smooth, and your in-game actions will be way more responsive. This can be the difference between victory and defeat in those fast-paced multiplayer arenas, where your reactions need to be lightning fast to win. After all, every millisecond counts.
- Extra CPU cores
Most of us use our phones for pretty much everything nowadays. Texting mates. Sending work emails. Doing a bit of online shopping. And if you’re anything like us, that means you’ve probably got a gazillion different apps and tabs open at once too.
The Nothing 2 will make light work of all that though. With extra CPU cores, this thing is a multitasking machine. Zip back and forth between even the chunkiest, power-hungry apps – all without lag. Swap from that facetime call with your nan to the holiday you’re in the middle of booking. Then check the weather over in Spain before your trip, and pop back to finish your conversation. There’ll be no slowdown in sight!
- Better charging wattage
Watts that? Higher wattage charging you say? Nice. The 45W charging function makes the Nothing 2 charge in a flash. So, you don’t have to wait around for ages twiddling your thumbs while your phone’s charging. Letting you spend more time doing the fun stuff.
Which of the two phones do you think you’ll pick up? Let us know in the comments down below.
