Please advise.
Best answer by Gregor
View originalBest answer by Gregor
View originalHello my daughter is in Tenerife right now and when I contacted ID Mobile they said because she is near the water, she will not have any signal at all.
She has to pay 30 euros hotel WiFi for a week so, that means when she's not in the hotel no connection still.
Wait what lol (“she is near the water”), they said that to you?
Has she logged in to her iD Mobile account and enabled the following two settings:
If Roaming and International are turned on, can you tell us what phone she is using?
Hi, thanks for your reply. My daughter said she had the roaming on from her IPhone 11 already. But still no connection.
We're in Tenerife right now and been sitting both on the beach and at the harbour, no problem at all with phone or data signal. Never heard of being near water causing a problem.
Just a thought, usually my phone would connect to a Spanish network automatically when we get to Tenerife. This time it didn't even after a restart. I had to go into settings hit the networks button then the available list came up. I chose Yoigo and it connected. I think that may be why your daughter can't get any signal at all, she needs to manually connect to a network.
Your daughter will need to ensure that Roaming is enabled not just on her phone, but in her iD Mobile account, too. As you can see from
Rory
Hi guys
Thanks very y, as Andy mentioned, my daughter finally managed to set it to..that and it's working now..
I appreciate all the input and yes that staff saying near the water was new to me as well,, He said because its not in mainland Spain and in an island thats why there was no connection. I've asked where in the ID Mobile website it was saying that and he said its not the but he just knew it, lol!! 😆
Anyway it's sorted and thanks again
Mrs S 😊
Hey
Glad to hear your daughter’s up and running now!
Rory
Hi, could someone possibly help please, daughter is in Tenerife and cant get her 4g to work, her phone and account both have roaming on it shows that she has 4g but it just wont work, it works ok with wifi when in the room, we have turned on and off both roaming features on phone and account, restarted phone and still nothing. TIA :)
Perhaps the APN value on your daughter’s phone is wrong
The APN value should be “id” (in lowercase).
Ty
Let us know if this works
She can also try going to the APN screen, tapping the 3 dots in the top right corner and then “Reset to Network Default”
Debbie
Hello
Please let us know how she get’s on and we’ll see what we can advise further.
Can you please confirm the issue you are having?
Is roaming enabled on the handset and the iD Mobile account?
Please can you also confirm the network you are connected to?
Hi kash thanks for taking the time to reply for some reason my location was saying Madrid when I’m in Tenerife I’ve switched that off now and that’s sorted the time and also for some reason on id I’ve got to lines personal and business and roaming was turned off on my personal line I’ve now sorted it thanks again
