Can’t make UK landline calls from Europe all my roaming is turned on and spending cap is on and I have both extra minutes too , nothing works and I really need to make landline UK phone call . Thank you .
Best answer by Mohammed
View originalCan’t make UK landline calls from Europe all my roaming is turned on and spending cap is on and I have both extra minutes too , nothing works and I really need to make landline UK phone call . Thank you .
View originalyes , i have even bought more minutes to add on but it doesn’t work
Is this all UK landlines, some UK landlines, or just one UK landline number
What numbers aren’t working?
Hey
You can’t call 0800 or 0808 numbers when roaming as these do not work.
Assuming it’s a standard landline like 01, 02 or 03, then it should work.
You can try switching to a different network as I had a customer with a similar issue today and there was a problem impacting calls on the network they were on and was fixed by switching networks.
What country are you in?
