Top tips to spring clean your phone
  • 23 February 2024
  • 84 replies
  • 24286 views
Badge +3
Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Good luck!
I like to use lemon scented cleaning vinegar on everything. It works a treat on all surfaces, can be diluted if necessary and smells lovely and fresh. I fill an old spray bottle so it saves on plastic waste too. I won’t go back to separate cleaning products now. Another hack is to use it in place of fabric softener, again smells good and leave clothes soft after a wash, just add a cupful to your wash.
Get yourself a RoboVac!!
Better still... win one from your mobile provider 😃
Hire a cleaner - simples
Userlevel 2
Clean a room at a time or clean as you go 👍
Rent a container (10’ X 16’) and bin all the things you haven’t used for 3 years, then when the weather is better go back and see if you wish to keep anything or wasn’t it worth paying to store it.
Langton
That's what the robots are there for
If you can’t reach the place you want to get to without standing on a chair, fetch a ladder!
Vinegar and baking soda get off a lot more things than you think! 🧼
Never leave a room without doing just ONE thing, however small, to make it cleaner! Trust me - when this becomes automatic, this works a charm. Failing that, buy an EUFY and let that little robot take the strain…
Magic sponge..  only cost a £1 and cleans of near anything that I've come across at work
Moving furniture to vacuum behind
Get someone else to do it…..😅
Once the cleaning is done, grab your favourite scented fabric softener or disinfectant, mix a capful with warm water in a spray bottle and spritz your walls. They hold the scent really well and make your house smell like freshly washed laundry
Have a quick look around for things you no longer use or need and sell, throw out or donate to charity. Why waste time cleaning and tidying things you don’t need to have cluttering up your life?
Some apps build up their own cache and become huge! Try deleting and reinstalling the app, and you’ll likely see it reduced in size dramatically (Meta apps are particularly bad at being efficient 🙂
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
I do my spring cleaning in the winter, usually just before Christmas.  That way I can enjoy the spring rather than let it pass me by.
Clean as you go
Well would need the Robot cleaner for the spring because Have a blower summer blow to 1 corner  Autumn to another Summer the third ready for spring to clean all !!
Never leave a room with your hands empty - if there’s rubbish that you can throw away a mug that’s been left out, making sure you pick something up before you leave the room is a great way to avoid clutter.
A nice new little 🤖  robot
Furniture polish on your shower screen olive oil on your stainless steel oven door.
I clean all stainless steel in the kitchen with baby oil,it brings everything so clean it looks brand new.
To spring clean, I start from the top of the house then work room by room, same in the rooms, work from the top down, from coving to skirtings to carpet seams, and all in between. Having a method makes sure you don’t miss anything. Buy the best product, to suit what you need it for, and always open a window to help circulate the air for a while.
When sorting your wardrobe out make sure all the hangers are the same way in the wardrobe over the next 6 months every time you wear an item hang it up the other way. After the 6 month period declutter the items you haven’t worn, either gifting to a charity shop or selling online. Either way it puts money in your pocket or the charity’s, winning all round.
Userlevel 2
I just try and keep on top of things year round but I have to admit that the low spring sun does show up the dust under the sofa. Oh well, get the vac out again.
Open windows as you start. The fresh air will energise you as you work by getting rid of stufiness
