Top tips to spring clean your phone.
  • 23 February 2024
  • 84 replies
  • 24535 views
Badge +3
Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Good luck!
Get my daughter to come and clean for me!
Strapped some tea towels to my babies legs as hes learning to crawl, Cleans the wooden floors better than any mop
Start with the top surfaces, end with the bottom floors. Little and often helps too!
Look at the files I have in Dropbox. Especially photos. I’m pretty sure I have many copies of the same photo, so you some software to automate comparision.
Start at the top of a room and work your way down so you’re not putting dirt/dust where you have just cleaned
My tip for spring cleaning:  Use natural and cheap cleaners.  The only things you ever need will be:
  1. Bicarb of Soda
  2. White vinegar
  3. Soda Crystals
  4. Bleach
  5. Salt
With those, which are cheaper and more environmentally friendly, you can clean anything.
Remove dust every weekend!
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
Carpet rake! It gets all the pet hair (or human hair!) and other little bits out of the carpet so it doesn’t clog up your hoover 🧼
Catch the Spiders 🕷️
