Hi, I have a iPhone 11 Pro that supports 5G but I don’t get it and I have just lost the ability to hotspot people
Page 1 / 1
Unfortunately, the iPhone 11 range doesn’t support 5G. This is only available for the iPhone 12 range and up. 5G coverage is dependent on both the phone you’re using, as well as availability in your local area. This can be viewed via the link below:
Check your network coverage | Support | Three
-Lauren
Reply.
