no signal
  • 29 August 2023
  • 37 views
Hi. I have an iPhone XS. I have had an ok signal for last four months whilst with I’d but now I have just one bar on 4g. Is it my phone. Or is it I’d?
If you’ve got no signal on iD Mobile’s network everywhere you go @Pamela Hancox, you might have a faulty SIM card or handset.
If the issue is in one place only, there could be a problem with the iD Mobile network in that location @Pamela Hancox
Check for faults online at https://www.three.co.uk/support/network_and_coverage/network_support.
Badge +5
Hi @Pamela Hancox
Is this in all areas or just certain ones?
Please could you let us know the postcode(s) where you’re having issues?
