I can't use my phone to call out or text.
My phone is saying that I'm not registered on a network.
How do I fix it?
How do I fix it?
I am having same issue - i am sure i already registered but it won’t recognise me. When i try to register again it won’t recognise the ID Mobile Number or my number that i wanted to transfer over from old provider. I can’t get into anything on myID Mobile. Getting so frustrated now after 3 days of trying.
Have you registered for the new iD Mobile account/app?
Once registered you’ll be able to login and manage your account.
It may also be worth checking the coverage and network status at the link below:
