a few days ago I realized that all my calls and messages are sent via wifi, the internet from my phone doesn't work anywhere, it shows the 5g network and full connection but I can't load any website
Best answer by Lauren
View originala few days ago I realized that all my calls and messages are sent via wifi, the internet from my phone doesn't work anywhere, it shows the 5g network and full connection but I can't load any website
View originalIf your mobile data doesn’t work anywhere, then perhaps it’s turned OFF on your handset or you’re using a faulty SIM card,Â
Â
Â
You would be able to collect a free iD SIM at any local Currys store. However, if you need one delivered to your home address, feel free to let us know. We’ll be able to send you a PM to set that up.
-Lauren
