Phone number issue
I have ported my phone number from my old android phone to my new apple phone. My calls are working perfectly fine but texting is being weird. When I message my friend who is on an apple phone as well it works, but when I message my mum who is on an android phone it doesn’t. She will text me and my old phone will receive the message instead of my new one even though it no longer has a sim card in it.
I went to Currys to ask about this problem and the two workers that I talked to were baffled. One of them was the apple specialist and even he said that he had never seen anything like this before.
Also, to create this message I’ve had to make an account even though I already had one. I went to reset the password on the other even though I’m sure it was correct and I didn’t even get an email. This mobile network is really confusing me, please help.
Best answer by Rory 10 May 2022, 09:45
Sounds to me like you have or had chat features enabled on your old phone. All you need to do is disable it!
https://messages.google.com/disable-chat
My android phone is no longer receiving the messages which is good but they’re still not coming through on my apple phone. Thanks for your help!
Userlevel 5
Hey @Rowan3012, could you please try the following steps for me?
  • 1) Turn off iMessage (Settings > Messages)
  • 2) Restart your phone (by pressing and holding the on/off button)
  • 3) Tap Settings > Phone > My Number and confirm that it is correct.
  • 4) If it is not correct, please enter the correct number
  • 5) Turn iMessage back to On (Settings > Messages)
  • 6) Finally, go to Settings > Messages > Send & Receive and see if the correct number is displayed under "Start new conversations from:"
Rory
