I used the app to change my Sim-only plan. However the My Account section of the app doesn't know about it and I've not had a related text. Do I need to repeat? Or be patient?
View originalI used the app to change my Sim-only plan. However the My Account section of the app doesn't know about it and I've not had a related text. Do I need to repeat? Or be patient?
View originalHello
I’d be inclined towards being patient.
The app and iD My Account online aren’t always in-sync and up-to-date with the iD billing systems.
If you’re concerned, use Live Chat between 9am - 8pm weekdays or 9am - 6pm weekends to speak with someone in customer service. If you connect in these time-periods and type “talk to a person”, you’ll get an iD agent and avoid the 24/7 bot.
Good luck.
Has this since updated?
This usually takes up to 24-hours if it’s just a plan change.
For upgrades, it’s when the new order is sent out which is when you’ll see the new plan.
Give us a shout if you still need help.
This screenshot taken a minute ago from the available plans shows the plan I'm currently on (£7/m) and the one I selected below (£6/m).
I chose this one as it has slightly more data with rollover for a lower monthly cost.
Richard
Has this updated in the app yet?
If not let us know and we can send you a PM.
