Best answer by Gregor
View originalPixel 3 dropping off Wifi and 4g
My Pixel 3 is frequently dropping it's WiFi or data connection. It's infuriating. It reconnects if I restart it or just wait a while, but as I've not had it that long, a few months, I want to actually fix the problem. I've updated everything. Help please 🙂
Hi @PmdPix
The easiest option for you would be to pop into your local Carphone Warehouse store. They can repair it for you and if the fault will be covered by warranty they will do it for free. Here is the link where you can find out more about repairs made by Carphone.
Kind Regards
Kind Regards
Why iD
Mobile?
