Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Want to give your house a good spring clean too? We can help you there as well because we are giving you the chance to win a brand new EUFY RoboVac 15C!
Simply write your response below and click reply.
Entries close at 23:59 on 14th March 2024, and we'll announce the lucky iD community winner shortly after.
Good luck!
