Cull your contacts
Organize your home screen
![](https://uploads-eu-west-1.insided.com/idmobile-en/attachment/e981a112-4b8f-4329-acbd-10a45c30844d.jpg)
Get rid of unused apps
![](https://uploads-eu-west-1.insided.com/idmobile-en/attachment/2f00b297-611d-45eb-b1ff-72681281a12f.png)
Delete photos and videos
![](https://uploads-eu-west-1.insided.com/idmobile-en/attachment/c4723f77-a800-43a5-a404-2a15de0aaf48.png)
Turn off location tracking
Clear your cache
![](https://uploads-eu-west-1.insided.com/idmobile-en/attachment/7e71a3fb-3ff7-485f-8b4d-4663ee26614b.png)
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
![](https://uploads-eu-west-1.insided.com/idmobile-en/attachment/e7e26fbd-c97f-4750-9995-2213d497abaa.png)
Want to give your house a good spring clean too? We can help you there as well because we are giving you the chance to win a brand new EUFY RoboVac 15C!
Simply write your response below and click reply.
Entries close at 23:59 on 14th March 2024, and we'll announce the lucky iD community winner shortly after.
Good luck!
