Top tips to spring clean your phone.
Nikhil P
Cull your contacts
Organize your home screen
Get rid of unused apps
Delete photos and videos
Turn off location tracking
Clear your cache
Reset. As a last resort
Wipe clean your phone
Giveaway Time!
Good luck!
80% found this helpful
MymsMan
Helpful
  • Helpful
  • 60 replies
  • March 1, 2024
Life is too short for cleaning!
  • 9 replies
  • March 1, 2024
Get yourself a brand new EUFY RoboVac 15C to do it for you.
Vinegar on glass or in your fabric conditioner tray. Also reduces limescale damage and no your clothes don’t smell like a chippy afterwards.
  • March 1, 2024
Hoover out your fridge and freezer before cleaning.
also remember you need a second hoover to clean out your first!
Sarahlb
  • March 1, 2024
Clean as you go so you don’t have a big task.
Do you know if you clean your vacuum cleaner, you are in itself a vacuum cleaner.
bluetoffee
  • 6 replies
  • March 1, 2024
Clean windows with a window vac, you’ll never look back...
  • 27 replies
  • March 1, 2024
Use a lint roller to dust lampshades or pick up spilled glitter and small beads
LoveMK
  • 15 replies
  • March 1, 2024
Sometimes Spring cleaning can seem like a big job. However I have found if you do little jobs, but often, you will slowly get it all done, without feeling burn out or giving up on the job altogether.
  • 42 replies
  • March 1, 2024
Those cleaning tasks I forget until almost too late, such as annual clean of the pond pump, reproofing the waterproofs; -  set them up on your To do list with the right date for next year. (Then you can intentionally “forget” them if you want!!)
CazP
  • March 1, 2024
White vinegar is the answer. It clears limescale, softens laundry, cleans windows and more. It's very cheap too.
Larsonsmum
  • 24 replies
  • March 1, 2024
Mine tip is to clean all year round, so there is no requirement for a massive ‘Spring Clean!
  • 16 replies
  • March 1, 2024
I read that coco cola has cleaning properties.
So i soaked a dirty old coin that I couldn't tell what it was. After 3 days' soaking, the coin became clean and recognisable.
I think I need to invest in a metal detector to find some ancient coins in a field and then clean them in coco cola and hopefully, find a small fortune.
Hope grows eternal. Where are we without hope?
Pom01326
  • 16 replies
  • March 1, 2024
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
Make a note of when your Phone contract runs out so you can switch to an ID sim only deal.
Sarah Mcritchie
Furniture polish on your shower screen olive oil on your stainless steel oven door.
  • March 1, 2024
It's not really a "cleaning" hack, but if you're struggling for storage space, get some vacuum bags and put your winter clothes in them, then pack them away somewhere. You'll be surprised just how much space you save thanks to sucking the air out of things! At the end of Summer, switch them with your Summer clothes.
  • March 1, 2024
Wear rubber gloves.
A wipe never hurts,
on a phone, make sure you’re backed up
and at home, make sure the cleaning sprays are appropriate for the surface, dont bleach your drapes!
Pom01326
  • 16 replies
  • March 1, 2024
Make a note of when your phone contract ends. You can then switch to an ID sim only contract.
Pom01326
  • 16 replies
  • March 1, 2024
Cull your contacts
Clear your cache
Giveaway Time!
Good luck!
Thank you.
Jamie-Kevin Faülkner
I microwave a lemon and move the vacuum to another room so it looks and smells like I’ve cleaned  works like a charm.
  • March 1, 2024
Like many things - little and often is best - that way things don’t get too messy and the jobs don’t seem overwhelming.
Sue
  • 16 replies
  • March 1, 2024
You need vinegar and rubber gloves windows will be cleaned ...
Mick2122
  • 12 replies
  • March 1, 2024
In springtime's bloom, with dust and grime,
My dear wife waltzes, she's quite the prime.
With mop in hand, and feather duster too,
She conquers chaos, there's nothing she can't undo!
Oh, how she sweeps with such grace,
Leaving no speck, no trace to erase.
She's the queen of clean, the guru of shine,
In her domain, dirt dare not recline!
But fear not, dear hubby, in her cleaning spree,
For I've got a hack, just for thee.
To win her heart and perhaps that vac,
Listen close, here's my little knack:
A massage for her weary shoulders, oh so kind,
A cup of tea, her favorite, you'll find.
And when she's relaxed, with a smile so bright,
Present her with the vacuum, to her delight!
For in the realm of spring cleaning, my friend,
A little gesture goes a long way, in the end.
So let her know she's the best, beyond compare,
With a RoboVac gift, you'll surely fare!
Victoria Evans
Baby oil is the only thing I have found that removes rubbery marks from patent shoes. I think it is rubber from the sole that transfers when kicking my own feet???…can’t think how else it gets there! A little baby oil gently rubbed on using cotton wool totally removes these marks 😊
