I have been with iD on a sim-only deal and was supposed to be sent a £30 voucher, just wondering how long this takes to be sent out TIA.
Best answer by Kash
View originalI have been with iD on a sim-only deal and was supposed to be sent a £30 voucher, just wondering how long this takes to be sent out TIA.
Best answer by Kash
View originalHi
Could you let us know a little more about the voucher itself?
Was this an offer with your purchase?
Is this part of the refer a friend program?
Hi, thank you for the reply. Yes, it was an offer with my purchase and not refer a friend. Hope this helps.
Did you locate the iD SIM only product, which you then went on to purchase, on an affiliate site
Yes, that's correct, thank you.
Welcome to the murky world of online promotions and rewards
The voucher offers on MSE are provided by GiftCloud, whom you would need to contact with proof of eligibility.
Many thanks for the help.
