fair usage caps - unlimited data plan within uk not roaming
  • 24 January 2022
  • 202 views
Hello!
I recently moved home and have been considering using my unlimited data plan for internet connection in the place of getting broadband installed. I just needed to check that there is absolutely no fair usage cap and I wish to avoid any additional charges or finding myself without any connection.
I will not be roaming at all, simply using it at home, and wifi in other places where available.
Any guidance would be hugely appreciated,
Thank you!
@Louise Sloan,
If you have unlimited data you can use your phone as a hotspot with no limits.
I hope this helps.
