How much of your data is rolled over from your original allowance? Is it capped or is it whatever you haven’t used?
For example on a 40Gb allowance if I only use 10Gb is 30Gb rolled over and so next month I get 70Gb allowance?
I know it only lasts a month, but let’s say it does above, and then only use 10Gb again, does it use rollover data first? So the month after I’d have 80Gb?
Best answer by Rory
