I am unable to receive calls
  • 5 March 2024
  • 156 views
I transferred to ID on Friday 1st March and imported my old mobile number. I have not been able to receive any calls, the caller ends up being directed to voicemail yetI have no missed calls or even calls registered. It also appears of I use SMS messaging the ID number shows. Although when I got someone to call this number it was not recognised.
Have you tried a NETWORK RESET on your handset, @Cookeaz?
Your device user guide should explain how to do this.
@andewhite no I haven't I will have a try. Thank you for the suggestion
Hi @Cookeaz,
Just checking how you got on after the network reset?
Please let us know if you are still having issues and we can help.
Hi @Kash  it appears I am still not receiving all incoming calls. I tried the Network Reset and my sister got through but I have since had others not be able to get through, like the Doctors surgery, school and intercom system.
Is there anything else you can suggest
Hi @Cookeaz,
For the last week I have suddenly been unable to receive calls. The caller just gets a series of beeps at their end and I get no missed calls message as the phone is unobtainable. I can however make calls. I have tried Network reset, and tried 2 different new SIM cards and still have the same problem. Has anyone else had this problem and if so how did you resolve it?
Userlevel 3
Hey there @Wendy Johnson, we’re very sorry to hear that. Just to check, when you go into your phone settings, is the correct phone number showing?
