Hi, have switched over to iD and have a PAC code from Sky. I have tried to register it but am getting an error because information isn’t recognised. Am sure my info is correct. The only question mark possibly is because I switched through Mobiles.co.uk. I have seen their order ref. is the transaction ref. for the PAC switch. Anyone any idea what I am doing wrong?
If you gave your PAC to “mobiles.co.uk” at the time you ordered, I’d guess they’ve submitted the PAC on your behalf.
A PAC can only be used once, so trying to submit the same PAC again will fail, but the iD error message may not be helpful.
What do “mobiles.co.uk” advise
Why iD
Mobile?
