My phone has suddenly turned off, and will not turn back on. There is no physical damage that I can see and this was really unexpected. The battery was on around 80% so that was not the issue, nothing will show if i plug the charger in. The factory reset would not work either.
I am using the iPhone SE
Have you tried holding down the Power + Vol down button together for 15 seconds to see if this help power the phone back on? Please can you try this with the charger plugged in.Â
If this does not work, then please can you connect the phone to a Computer/Laptop which has the latest version of iTunes to see if the phone switches on.Â
Â
-Mohsin
I’ve tried doing both of these options however the screen is still blank, is there any other way I can try to fix this?
Â
Why iD
Mobile?
