Roaming in USA with cap limit
  • 22 May 2022
  • 1065 views
Hi I am in the USA for 4 days and within an hour of landing I had used up my £5 price cap for roaming charges. I need to use roaming to get around for navigation but I can only extend price cap to £75. Is there an add on I can buy for international roaming or remove my cap for this month? Otherwise I am stuck
Best answer by Rory 24 May 2022, 14:03
Unfortunately, iD Mobile don't have any packages/add-ons for Roaming in USA.
You will have to set the cap at £75.00 and maybe make a manual payment as and when needed (before cap limit is reached).
Userlevel 5
Hi @Billjames7, just to clear something up from @WelshPaul’s post, making a manual payment wont reset or increase the cap, so £75.00 is the maximum amount of additional charges you can accrue in one billing cycle.
This maximum cap is based on the results of the credit check we carried out when you first joined us and is designed to protect you and your financial health.
If you need mobile data access while you’re in the USA, I’d recommend obtaining a local Pay As You Go SIM which should work out to be much cheaper.
Rory
