SmartWatch Compatible
  • 16 August 2023
  • 1481 views
Hi I was wondering is the ID Mobile network compatible for pairing a smartphones cellular data to the Galaxy 6 SmartWatch LTE? I currently have a Watch6 Classic LTE but I want to connect it to my smartphones data network for the cellular data for calling and messaging. My current provider doesn't support it. It comes up with it needing a QR/activation code when trying to connect the smartwatch which my current mobile provider doesn't provide. I don't think it will need a code though if the network provider is already compatible.
Best answer by Mohammed 17 August 2023, 16:28
If you want a cellular plan for your watch then you need to go with Vodafone, EE, O2 or Three. Be prepared to open your wallet! Their plans ain’t as cheap as the MVNO’s and you’re going to incur an additional charge for the watch plan to boot.
Hello @Wolfy,
This feature isn’t one we currrently support on the network.
Sorry about that.
