Two numbers?
  • 7 November 2023
  • 196 views
I have recently switched over to ID and have imported my number which was done successfully, I can text and call with my previous number which I wanted, but with iMessage and facetime to other people with an iPhone, it is a different number, does anyone know why? Thank you.
Best answer by Tom 8 November 2023, 12:17
Have you tried a NETWORK RESET @Kourtney Greenwood?
The Apple iOS user guide would normally explain how to do this.
Hi @Kourtney Greenwood
I’d recommend checking the settings in your device as below;
Settings > Phone > My Number
If the number there isn’t correct, it might be worth trying a network settings reset as suggested by @andewhite.
Let us know how you get on.
